Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2007 Honda Pilot overheating
Old Jul 4, 2018 | 02:31 PM
WyandotteRon's Avatar
Default 2007 Honda Pilot overheating
I bought a 2007 Pilot with a leaking radiator. I replaced the radiator with a new one. I followed some YouTube procedure to get the air out of the system. The engine still overheated so I replaced the thermostat. Again I let the engine run with the heater on and the radiator cap off to get the air out. It idled for nearly an hour and the temperature gauge never went over half. I shut it off, topped off the coolant, put the cap on and headed down the street. I didn’t get one block before the temperature gauge was maxed out on hot! What could be wrong?
Old Jul 4, 2018 | 02:41 PM
2x0's Avatar
2x0
10 Year Member
Default Re: 2007 Honda Pilot overheating
Could have a headgasket issue now since it overheated, might have warped something. While bleeding the coolant, rev it up and see if it makes bubbles. Is it pushing coolant out the overflow?
Old Jul 4, 2018 | 02:59 PM
I sure hope there’s no head gasket issue. I just bought it knowing the radiator had a leak. The past owner had it regularly serviced at his local Honda dealer and it started leaking the day I tried it out. The motor starts and runs smooth and as long as I have the radiator cap off, the temp is normal. As soon as I put cap on and start down the street, the temp climbs to the H.
Old Jul 4, 2018 | 03:02 PM
It has had the timing belt and water pump replaced 12k miles ago along with all the fluids changed, even the brake fluid.
Old Jul 4, 2018 | 03:04 PM
It made lots of bubbles while bleeding and when I shut it off the coolant was sucked in. I was able to add about a gallon of coolant and thought I got the air out.
Old Jul 4, 2018 | 04:02 PM
holmesnmanny's Avatar
make sure both fans are running when the car starts to overheat, if the fans are running then you need to compression test to see if the head is leaking
Old Jul 4, 2018 | 05:46 PM
Both fans run when it’s overheating.
It will idle for an hour without overheating if the cap is off.
ShotnVA777
Jan 9, 2014 04:13 AM
daprchamp
Jun 11, 2011 04:14 AM
new_climber
Dec 14, 2008 10:07 PM
acmoc
Apr 2, 2008 03:03 PM
Shintakun
Honda Civic (2001 - 2005)
Jan 26, 2008 07:44 PM
