water missing help
Old Jun 10, 2011 | 08:05 PM
daprchamp's Avatar
Default water missing help
i just replaced my thermostat on my 93 honda accord and the rubber gasket that comes off the top tube from the radiator .. the car dont over heat but when i come home from work and check it ... the radiators empty all the water that was missplaced is in the ****ing plastic bottle sitting to the left if ya standing over the radiator ... is this normal ... and if not is there away to fix it
Old Jun 10, 2011 | 08:11 PM
nus_dogg's Avatar
Default Re: water missing help
Are you talking about the rubber gasket on the radiator cap?? I don't remember seeing any rubber gasket that comes off the top tube from the radiator.
Radiator shouldn't be empty.
Old Jun 11, 2011 | 04:14 AM
GhostAccord's Avatar
The overflow should fill up more when the engine is hot, then as the engine cools it should suck the "overflow" coolant from the tank back into the radiator/engine.
When you removed the rad cap to check the radiator was there any vacuum or pressure?
When you did the thermostat change did you completely bleed the coolant system of air? Also are you using just water or a coolant mixture?
mnaffay205
Nov 7, 2014 06:42 AM
civicsir94
May 20, 2008 03:21 AM
acmoc
Apr 2, 2008 03:03 PM
clean3two3
Oct 17, 2007 12:54 PM
blackEF
Oct 29, 2002 12:24 PM
