Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Which tail light socket for 08 Honda Accord EX
Old Jun 30, 2018 | 01:31 PM
Astarks's Avatar
Default Which tail light socket for 08 Honda Accord EX
I have brake/tail light out passenger side only. Not fuse and not bulb. I suspect the socket. There are three sockets, three different part numbers, listed for this car. Why are there three ( different countries?) and which one do I need (USA)?
Thanks!
Old Jul 1, 2018 | 09:53 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Which tail light socket for 08 Honda Accord EX
1. You can do some quick electrical tests if you have a multi-meter. Such as testing for:
  • Power on the red wire terminal cavity when headlight switch is turned on
  • Power on the light green wire terminal cavity with the brake pedal switch depressed
  • Continuity to ground on the black wire cavity terminal of the socket.
2. If you don't have a multi-meter, you can still do some other checks.
  • First look at the ground wires going to ground G602; refer to this other thread for the location. https://honda-tech.com/forums/honda-...rking-3313363/
  • You can also swap the brake light/tail light socket between the driver and passenger side to see if that is the cause.
3. The 3 sockets are for different functions; so, no, there are not 3 different part numbers for the brake/tail light socket. Only 3 different part number for 3 different sockets. Only caveat, is that there may be a part number difference between coupe vs. sedan. Is your car a sedan or coupe? Regardless, the brake/taillight socket Honda part number is 33515-S50-003 for sedan and coupe.
  • One socket is for the back-up (reverse) light
  • One socket is for turn signal light
  • One socket is for brake/taillight
Natasha Akers
Aug 14, 2012 09:02 PM
OneFire
Jun 2, 2011 09:07 PM
uraburr
Audio / Security / Video
Jan 13, 2010 04:55 PM
h0tsihatch
Jun 1, 2004 06:30 PM
