Which tail light socket for 08 Honda Accord EX
I have brake/tail light out passenger side only. Not fuse and not bulb. I suspect the socket. There are three sockets, three different part numbers, listed for this car. Why are there three ( different countries?) and which one do I need (USA)?
Thanks!
Thanks!
Re: Which tail light socket for 08 Honda Accord EX
1. You can do some quick electrical tests if you have a multi-meter. Such as testing for:
2. If you don't have a multi-meter, you can still do some other checks.
- Power on the red wire terminal cavity when headlight switch is turned on
- Power on the light green wire terminal cavity with the brake pedal switch depressed
- Continuity to ground on the black wire cavity terminal of the socket.
- First look at the ground wires going to ground G602; refer to this other thread for the location. https://honda-tech.com/forums/honda-...rking-3313363/
- You can also swap the brake light/tail light socket between the driver and passenger side to see if that is the cause.
- One socket is for the back-up (reverse) light
- One socket is for turn signal light
- One socket is for brake/taillight
Suke
11-09-2004 09:53 PM
