Honda Ruckus and Scooters Ruckus, Silverwing, Reflex, Helix, Metropolitan
Slight wobble on rear wheel
Old Jun 25, 2018 | 10:39 PM
Xvisor's Avatar
Default Slight wobble on rear wheel
There is a slight wobble from left to right maybe 3mm. Is that normal for a ruckus
Old Jun 26, 2018 | 07:25 AM
sTol2m's Avatar
Default Re: Slight wobble on rear wheel
What are you running, the stock wheel or a custom wheel with a hub?
The stock wheel could be bent. Does it wobble at speed or when not moving? (or both?)
If you have a fatty wheel, (DWT polished aluminum) then it is normal because its two wheels welded together and not balanced properly.
Check the axle nut and/or lug nuts are tightened. Maybe try Dyna-Beads to balance it.
Old Jun 26, 2018 | 07:42 AM
Xvisor's Avatar
Thanks for responding. I don’t believe the stock wheel is bent. It just moves very slightly left to right when I move it. No accidents or lay down.
Old Jun 27, 2018 | 08:23 AM
sTol2m's Avatar
Ok I did some checking, and yes it is a common problem.
It could be the wheel bearings need replacing, a bent axle(I hope not), or the washer is missing for the axle nut.
The stock wheels are not the best quality steel and have a tendency to warp after falls or potholes.
Take the wheel off and check for axle wobble. Check the wheel bearings for damage. Double check that axle nut & washer are tight.
Hope this helps.
Rick James
10
Sep 25, 2008 05:07 PM
ITRDC2R
Jun 1, 2007 05:43 AM
cmyrex
Nov 14, 2006 08:28 AM
Chicano
11
Jan 19, 2005 08:14 PM
Essence of Chicken
Dec 18, 2003 11:21 PM
