CAN SOMEONE PLEASE TELL ME THE BEST WAY TO REMOVE THE PUSH NUTS ON THE PLASTIC POSTS CONNECTED TO THE ARMREST BADGE THATS UNDER THE BOTTOM SIDE OF THE ARMREST?
I BOUGHT A NEW ARMREST AND WAS GOING TO SWITCH THE BADGE (IF IT WERE EASY) BUT I ALSO BOUGHT A NEW PLASTIC BADGE HOLDER AND MIGHT JUST SWITCH THE METAL BADGE INSERT USING A NEW BADGE PLASTIC HOLDER
GRAB THE WASHER WITH NEEDLE NOSE PLYERS (BASICALLY THE FIRST TOOTH ON THE END OF EACH PLIER) AND SQUEEZE JUST ENOUGH TO BE ABLE TO SPIN AND PULL UP
KEEP SPINNING THE PUSHNUT AND PULLING UP AT THE SAME TIME AND IT WILL SLOWLY COME TO THE TOP OF THE POST AND THEN OFF
LEAVES SCUFFED POSTS BUT STILL COMPLETELY IN TACT AND ABLE TO RECEIVE A NEW PUSH NUT
