b18c swap into a 1996 civic ek
Old Jun 19, 2018 | 10:47 AM
scoobntaz1996's Avatar
Default b18c swap into a 1996 civic ek
my son and I swapped a b18c into a 1996 civic ek. everything is hooked up but I"m not getting spark or fuel. I have checked all the grounds and replaced the main relay. we are using the stock wiring harness as the original motor was a y8 vtec. any suggestions are greatly appreciated.
Old Jun 19, 2018 | 10:54 AM
tony_2018's Avatar
Fish Twig
Default Re: b18c swap into a 1996 civic ek
the thermostat ground?
Old Jun 19, 2018 | 10:58 AM
Yeah checked that already. Someone said I might need a third ground from the valve cover to the body.
Old Jun 19, 2018 | 11:02 AM
tony_2018's Avatar
Fish Twig
What ecu code? jdm or usdm?
Old Jun 19, 2018 | 11:17 AM
Usdm
Old Jun 19, 2018 | 11:18 AM
tony_2018's Avatar
Fish Twig
is it obd2a or obd2b?
Old Jun 19, 2018 | 11:20 AM
Obd2a
tony_2018's Avatar
Fish Twig
Your civic is an obd2a, you need an obd2a ecu. Another thing to check is that thermostat ground because it provides a ground for the main relay and the ecu to prime fuel and let the ecu fire the injectors.
If you're not getting spark you need to find out why your harness isn't powering the distributor.
Ecu is obd1
Old Jun 19, 2018 | 11:22 AM
Were using a jumper
tony_2018's Avatar
Fish Twig
Try another ecu.
Old Jun 19, 2018 | 11:24 AM
Have tried three different ecu's lol
Old Jun 19, 2018 | 11:28 AM
tony_2018's Avatar
Fish Twig
You didn't state that lol
Old Jun 19, 2018 | 11:29 AM
I apologize for that. I also wrote ek in the original thread it's a ex sorry
Old Jun 19, 2018 | 11:55 AM
tony_2018's Avatar
Fish Twig
so what else is missing LOL.
Old Jun 19, 2018 | 04:04 PM
HondaPartsHero's Avatar
Technical Hero
When you turn the key to the position before crank does the check engine light come on for around 2 seconds and then turn off (indicates main relay is activated) or does it come on and stay solid?
Old Jun 19, 2018 | 05:08 PM
We sorta figured it out. It was the main relay. But the jumper harness we got was obd2b to obd1. We hooked up the original ecu directly to the car and started, but like crap lol. My son is getting a p73 Obd2a spoon ecu for $100 bucks. So that should solve everything.
H Series Garage
Mar 2, 2017 04:15 AM
derrickkong888
Aug 28, 2012 06:43 PM
stevennn09
Feb 20, 2011 07:08 PM
martiniracing
21
Dec 5, 2009 10:55 PM
