coolent boiling after engine shutoff
Old Jun 17, 2018 | 10:58 PM
Wesfelty's Avatar
Default coolent boiling after engine shutoff
2007 honda nss 250 reflex. When I ride at 50 mph temp ok. When i slow down to 25, temp starts rising above normal. With engine shutoff, coolent boils. I leave ignition switch on until fan stops. I bought used so I don't know history but this is new problem.
Old Aug 1, 2018 | 01:20 PM
botboy's Avatar
Default Re: coolent boiling after engine shutoff
I can't speak to the 250's but on many bikes the fan will run after ignition is shut off to prevent coolant "percolation" since the water pump isn't spinning once you shut the engine off. If its percolating could definitely be low on coolant and causing your problems.
Old Aug 22, 2019 | 04:27 PM
Ozwald's Avatar
if the bike is getting hot just riding somewhat slow I'd say its low on fluids, both oil and coolant. if there isnt enough of it, even if the rest of the engine is able to circulate the fluids, there wont be enough throughout the system causing air pockets that just heat up the bike over normal temps. id suggest a full service of the bike since you dont know its history, and go from there.
nyhondaguy
Honda CR-V & Element
Dec 28, 2012 09:12 PM
prettyinpink
Oct 16, 2007 03:23 PM
christiian
18
Jul 16, 2006 12:03 AM
PrecisionH23a
Sep 13, 2005 10:23 AM
