1980 honda cm400t carb o ring help
So I bought a rebuild kit for my carburetors and I have two sets of different size o rings along with a thicker single o ring? I replaced the o ring for the idle screw and the fuel rail but can't seem to figure out were the rest are meant to go?
Re: 1980 honda cm400t carb o ring help
Those go to the carburetor that was built for a 1980 Honda CM400T. You have a carburetor for a 1978-79 CB or CM 400 I’m guessing. In 1980 the carburetors changed, and you’d need the correct kit for the correct carburetor. VB22A is what’s stamped on a 1980 CM400T carburetor. I’m pretty sure VB22C and VB22E are also okay for a 1980 CM400T.
v8killaz
02-29-2008 10:40 AM
