transmission shifts fine while not on but while car is running won't shift?
Old Jun 5, 2018 | 08:55 PM
CrossedUP's Avatar
Default transmission shifts fine while not on but while car is running won't shift?
2001 Honda Accord has issue with transmission shift while car is running. while the car is not running no problem shifting gears? is there an electrical issue with the Manual for this year?
Old Jun 5, 2018 | 08:58 PM
Humphrizzle's Avatar
Default Re: transmission shifts fine while not on but while car is running won't shift?
check your slave cylinder. have someone press the pedal while you look at the slave cylinder. if its not moving, replace it.
Old Jun 6, 2018 | 12:24 AM
holmesnmanny's Avatar
first check the fluid level, the master cylinder might be leaking and need replacing
Old Jun 6, 2018 | 02:24 AM
angrysmileyface's Avatar
Might have popped a spring in the clutch
GSRWSU
Oct 22, 2006 11:03 AM
Akalima
Sep 17, 2005 10:11 PM
mike1114
Jul 11, 2004 12:54 AM
mike1114
Jul 10, 2004 06:37 PM
del_parker
Sep 1, 2003 07:17 PM
