no speedo
Old May 28, 2018 | 09:23 AM
joeydd3's Avatar
Default no speedo
97 accord se vss code came up, speedo was sparatic just replaced the vss now the speedo is not working at all
Old May 28, 2018 | 04:02 PM
angrysmileyface's Avatar
Default Re: no speedo
Check the pins in the vss connector
Old Jun 16, 2018 | 01:40 PM
joeydd3's Avatar
replaced the vss,,checked the pins on the connection even cleaned them with qed cleaner,,,shifting problem has gone away but still no speedometer,and the 501 engine code came back . any ideas?
Old Jun 16, 2018 | 04:30 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
First check the connector to the VSS for corrosion on the terminals, damage to wiring, etc.
You'll need a multi-meter for testing.
Unplug the VSS connector.
VSS Terminal no. 1 (Blk wire) is the ground wire from Ground G101.
VSS Terminal no. 2 (Yel/Blk wire) is power when the ignition switch is in the ON or START position.
VSS Terminal no. 3 (Orn wire) is the VSS output which goes to the ECU, cruise control unit, and the gauge assembly.
1. With the multi-meter set to the voltage setting, measure the voltage at terminal no. 2 (Yel/Blk wire) with the ignition switch in the ON position (car is not started or running).
Multi-meter red lead touching terminal no. 2 and multi-meter black lead to body chassis ground (car's bare metal or a ground bolt).
There should be battery voltage on terminal no. 2 (standard battery voltage is 12 volts).
2. If there is battery voltage in step no. 1, do the same test to measure voltage at terminal no. 2; but, this time touch the multi-meter black lead to terminal no. 1 (blk wire). Is there battery voltage?
This test is to check for ground coming through terminal no. 1.
3. With the multi-meter set to the voltage setting, measure the voltage at terminal no. 3 (Orn wire) with the ignition switch in the ON position (car is not started or running).
There should be no voltage on terminal no. 3 with the VSS disconnected. If there is voltage on terminal no. 3 with the VSS disconnected, there is a short somewhere.
If the previous tests were okay, then plug the connector back on to the VSS.
1. Jack up and properly support the car with jack stands.
2. With the ignition switch in the ON position (car not started or running), back probe the VSS orange wire terminal.
Backprobing is either using a backprobe set or using a thin needle or something and making contact with the metal terminal of the connector without piercing the wire in the back of the still connected connector. Care must be taken to ensure that the wiring does not get damaged. You can use something like a T pin, available at Walmart, etc., and backprobe. These pictures are just to give a picture of the concept of backprobing without piercing any wires.
https://www.hondaaccordforum.com/foru...%5D-t-pins-jpg
https://www.hondaaccordforum.com/foru...back-probe-jpg
Spin the passenger side wheel slowly. The voltage measurement on the VSS orange wire suppose to pulse from 0V to approx. 5V.
suproman
Oct 25, 2010 12:11 AM
2000CivicEK
11
Jun 18, 2009 05:50 PM
Blazin Si
Audio / Security / Video
Apr 30, 2009 03:11 PM
uncle L
Jul 26, 2007 08:29 PM
dingusjt
Nov 13, 2003 08:41 AM
