Suspension & Brakes Theory, alignment, spring rates....
Which suspension to go with for 97 Del Sol?
Old May 26, 2018 | 09:40 AM
Randolph's Avatar
Default Which suspension to go with for 97 Del Sol?
So I picked up a 97 Del Sol Si with 147k for about $700. It has these Ebay coilovers with stock struts maxed out which rides absolutely horrible here in New York. I'm going to raise it back up asap so I can at least drive the thing but I been doing research on here and Google for different spring rates and tried/true setups. I been reading up a lot on koni/gc with extended top hats. I want to keep it this height but I want it to ride a little more stiffer. I obviously know it isn't going to be smooth. I saw 450f and 350r is the norm for rates. Just a daily driver, nothing crazy. Anyone have any ideas?
By the way these ebay's are MAXXXED tf out at a 5 inch drop!
Old May 26, 2018 | 07:24 PM
BondoCRex's Avatar
Default Re: Which suspension to go with for 97 Del Sol?
You want it to stay at the ride height it's at in this picture?
Old May 26, 2018 | 09:35 PM
Randolph's Avatar
Maybe a little higher like 3 or 4 inch drop
Old May 30, 2018 | 02:42 AM
NVturbo's Avatar
O.G. triple O.G.
You mean a 1.5" or 2" drop? You can get some Progress CS2's for under $600 with 450/350 spring ratings. That's what I have on my Del Sol.
Old May 30, 2018 | 02:48 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
a 3 or 4" drop!!!!!! COT dang.
pick a full body adjustable coilover. it will ride badly. but...maybe not as badly?
Old Jun 17, 2018 | 05:04 PM
Randolph's Avatar
how does it ride with the 450f 350r spring rates? How much of a drop is that on your Soul?
these ebay's are trash I want to set them on fire when I buy my new coilovers like wtf
Old Jun 17, 2018 | 06:50 PM
B serious's Avatar
I doubt that any single-point adjustable shock is going to work as well as it is designed, at the heights in any of these pictures.
450/350 isn't a very high spring rate. As long as the shock can handle 450/350 + whatever the bumpstop rate is, they will ride "ok" (ok meaning "like ****" in real world terms).
I don't think progress recommends a 3 inch drop. Its a small car. That black Del Sol looks to be lowered a lot more than 2".
I doubt any reputable company recommends using a 3" drop....even if their setup is capable of doing so. Most street setups even caution against using a 2" drop for the sake of ride quality.
What I'm saying is that its going to ride badly regardless of what you use. Which is fine if you're willing to live with the diminished ride for the sake of looks.
Old Jun 18, 2018 | 12:10 PM
CandyRedRC46's Avatar
https://bcracingcoilovers.com/collec...nt=25855012613
"extreme low"
That isn't to say this will solve all your issues, like upper control arms hitting the strut towers, tires hitting the top of the fender wells and other parts bottoming out, out of range...
Generally, the lower you go, the higher the spring rates you will need, in order to prevent bottoming out.
Just pick a decent coilover and set it to a reasonable height. Stop destroying what old hondas we have.
Old Jul 19, 2018 | 02:27 AM
NVturbo's Avatar
O.G. triple O.G.
They ride fine. I can't recall how much drop it actually is. I'm guessing 2" or so.
Yeah, never buy no-name coilovers on eBay. You'll just be throwing money away.
xDelSolx93
46
Oct 15, 2011 04:53 PM
Mike97LS
Sep 23, 2008 02:59 PM
ProjektSol
22
Jul 17, 2006 10:35 PM
phantom_sol
13
Oct 28, 2003 01:51 PM
Bassicfun
Jul 18, 2002 04:40 AM
