What Suspension Set up fits for my car
i have 1997 Honda Del Sol Si SOHC
i heard it fits with 92-95 eg but im not really sure can someone please help me
Re: What Suspension Set up fits for my car (ProjektSol)
The 97 Si sol has the same suspension as the VTEC sol. That said if you want to upgrade the 92-95 civic will be what you want.
Re: What Suspension Set up fits for my car (onefast93sol)
are you saying that the 97 del sol suspension setup is the same for a 92-95 civic?
You can get EG coilovers but keep in mind that the Sol is heavier and that means that you won't have the correct spring rates, which means that your car will be a little lower than a civic with the same components.
Nothing to worry about , people do this all the time. Make sure you get an alignment and set your toe to 0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSol »</TD></TR><TR><TD CLASS="quote">are you saying that the 97 del sol suspension setup is the same for a 92-95 civic?</TD></TR></TABLE>
Yes.
Yes.
Re: (ProjektSol)
Um...well del Sol parts are pretty much specific for the car. The only thing other than engines/suspension that will swap is a civic front lip. The suspension is that of an EG as stated above.
Re: (fast95eg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast95eg8 »</TD></TR><TR><TD CLASS="quote">Do not get EK suspension. The rear shocks are different.</TD></TR></TABLE>
exactly.. the fork at the bottom of the rear shock is smaller and will not fit your lcas
eg and integra can go on an ek (washer spacer) but not the other way around...
Re: (ProjektSol)
what about integras? will the suspension fit?
if so then i believe it will...
as for rear shocks only
integra compatable with eg and visa versa...
ek can use integra and eg, but not the opposite
Re: (aallbbeerrtttttt)
are you sure i can use integra coilovers?
because my bro has a 97 integra and i dont wanna go through all the trouble jackin my car up and stuff
Re: (ProjektSol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjektSol »</TD></TR><TR><TD CLASS="quote">are you sure i can use integra coilovers?
because my bro has a 97 integra and i dont wanna go through all the trouble jackin my car up and stuff </TD></TR></TABLE>
you can use integra components. from 94-01.
you can use civic components. from 92-95
you can even use type r as long as you change out the rear control arm and strut.
TRYLSTEG808
01-05-2008 12:11 AM
deadlock32
03-02-2006 07:36 PM
