cooling fan problem
Old May 24, 2018 | 11:46 AM
john79's Avatar
Default cooling fan problem
I am trying to troubleshoot my cooling fan problem. I try to jump the cooling fan switch but it didn't work although it did earlier. I tested the fuse box and the relay and the motor and they are all working. where is the problem knowing that the circuit must be intact because I the fan runs when I turn on the AC
Old May 24, 2018 | 08:49 PM
Freedo_Civegra's Avatar
Default Re: cooling fan problem
You tried jumping out the plug for the switch on the thermostat housing, and got something but now nothing? Check the ground and ground wire for that switch.
Old May 24, 2018 | 09:48 PM
tony_2018's Avatar
Fish Twig
detail your tests
Old May 25, 2018 | 02:21 AM
john79's Avatar
Sorry but how to do that ?
Old May 25, 2018 | 02:32 AM
john79's Avatar
Originally Posted by tony_2018
detail your tests
1. Tested the relay and it was working fine (applied power to terminal 3,4 and tested the volt in terminal 1,2)
2. Tested the motor of the fan by applying direct power from the battery and it worked...
Fan also works when I turn on the AC
3. Tried to jump the cooling fan switch (pig tail connector ) initially it worked
4. Thought may b something wrong with the wiring to the Pig tail connector and tested the volts in the connector and found its 5v
5. Jumped the pig tail connector again and tried to check power going to the fan and I found no power going to the fan with the pig tail connector jumped
Old May 25, 2018 | 05:04 AM
Run a jumper wire from the green wire’s terminal to ground.
xTomei
Jun 18, 2010 03:09 PM
rohec04
Sep 26, 2008 09:52 AM
ge_itr
Jun 5, 2007 09:12 PM
manny81
Apr 22, 2007 12:23 PM
hondateg10
Apr 5, 2007 08:41 AM
