Fuel meter shows full
Old May 24, 2018 | 11:17 AM
ScruffyScrews's Avatar
Default Fuel meter shows full
I got a 96 Civic Dx and i changed the cluster to one that shows the rpms. The fuel always show its full when it wouldnt be. It doesnt move at all. Can anyone help me get it to read the right level of gas and get it to move?
Old May 24, 2018 | 12:05 PM
Chance EG's Avatar
Default Re: Fuel meter shows full
Few different things can cause this. Sending unit in the tank, the cluster itself, or the wiring are all possibilities.
You can try using high proof rubbing alcohol to clean the contact points/copper connections on the back of the cluster to see if that helps anything. Sending unit can be tested with a voltometer, costs like $15->$20 to replace I think. The little rubber stopper can sometimes get "stuck" in a certain position too depending on what the situation is in the tank, and if there's an aftermarket fuel filter in there that's getting in the way. That's unlikely for you though if it's at 100% full.
Checking the signal at the sending unit would be the best way to determine quickly and correctly.
Old May 24, 2018 | 12:13 PM
Okay I can try that I do remember when I tired to lower it by hand it will always go back up to full. But I'll rub the points with rubbing alcohol.
ajjct
May 21, 2013 01:19 AM
JDM_WHR
10
Jun 7, 2010 08:50 AM
tifosi
Jul 11, 2008 10:13 AM
spoonef
Feb 23, 2003 02:31 AM
cheezemaster
Sep 19, 2001 09:10 AM
