How does one remove Arp rod bolts that are already machined in stock rods
I have some ls rods and they have arp rod bolts on them. I wanted to take them out since they were in good condition but I've tried all I can to get them out.. what should I do?
They won't work with an aftermarket rod set... aftermarket rods use a single piece bolt while the ARP replacement bolts (for stock factory connecting rods) are actually special headed bolts used in conjunction with a matching cap nut. In addition, if you cannot say for certain how many times the used bolts have been used/torqued/loosened/re-torqued... I suggest you save up instead of placing your engine at risk.
