98 Civic rear disc brake conversion
Old May 2, 2018 | 10:24 AM
kmarshall57's Avatar
Default 98 Civic rear disc brake conversion
I assume that the Honda dealer will not provide this service
Old May 2, 2018 | 12:01 PM
rick_rabies's Avatar
I'm not Rick!
Default Re: 98 Civic rear disc brake conversion
you are correct. but its very very simple.
I would just get the bracket to bolt on caliper instead of swapping whole thing out.
www.fastbrakes.com
Old May 2, 2018 | 01:48 PM
Feriohhh's Avatar
5 Year Member
Dealer is unlikely, but you might get some help from a small independent shop.
You can get the bracket swap kit as mentioned above or just go with OEM Honda parts:
94-2001 Integra (all except Type R) rear trailing arms with disks and calipers
or
93-97 Del Sol Si or VTEC rear trailing arms with disks and calipers
or
99-2000 Civic Si rear trailing arms with disks and calipers
and
99-2000 Civic Si parking brake cables
The trailing arms with disks and calipers shouldn't cost you much more than 100-150 bucks at just about any wrecking yard. The cables you can still buy new from Honda. It all bolts up like factory. Optionally you can look into a 15/16-inch or 1-inch master cylinder and brake proportioning valve for a 4-wheel disk car.
Old May 2, 2018 | 05:54 PM
Aesyrin's Avatar
If going for the trailing arm route, does it matter if it's from a JDM or USDM Integra?
Old May 3, 2018 | 03:58 AM
mostwanted_ek's Avatar
no, it's all the same..
Old May 3, 2018 | 04:47 AM
I'm not Rick!
you can use the type R rear also if your froggy but you must use type r rear lower control arm and shock
Old May 3, 2018 | 06:21 AM
Freedo_Civegra's Avatar
Does that proportioning valve(?) on the firewall need swapping from an EX/Si?
Old May 3, 2018 | 08:05 AM
I'm not Rick!
if your doing the swap. and you don't have abs...get the non abs prop valve.
you can go without the prop valve....but it would behoove you to do so. it actualy makes a big difference.
also...if you really wanted brake power get integra brake booster and master cylinder...GSR parts are bigger. type r are even better.
I had GSR front and rear brakes on my EG with GSR brake booster and master and prop.....stopped very well
Old May 3, 2018 | 08:50 AM
All good points. Won’t the Integra master cylinder and booster make the Civic brake pedal sit lower? I read something about that one time, I think.
Old May 3, 2018 | 09:02 AM
I'm not Rick!
no. your not touching the brake pedal at all. the pedal stays
Old May 3, 2018 | 10:02 AM
Ok, didn’t know if there may be a difference in push rod length. Thought I’d throw that out there just to be sure a base was covered.
Old May 3, 2018 | 10:05 AM
I'm not Rick!
no its the same. the bore is what is different. basically has a large fist pushing more fluid pressure.
and to have more detail you need the 40/40 prop valve. that's the desired (term) not the 40/20
theres a guy in the marketplace selling a conversion bracket setup and calieprs.........
Old May 3, 2018 | 02:19 PM
Yup, that’s why I got a 1” bore ITR M/C... The pedal to booster pushrod was what I was thinking of, btw. It’s gotta be the same, like you said. Idk what I was thinking.
Cap'N Chronic
Mar 27, 2022 07:16 AM
speedracercivic
10
Mar 5, 2007 07:06 PM
Civic98KH
Mar 4, 2007 05:52 PM
Mr. Choi
25
Oct 2, 2004 09:03 AM
