SI Rear Disc Brake Conversion
i found an entire assembly for 380.00 ... now this is what i get with it...
Used OEM Honda Factory Part.
Complete Rear Disc Brake Set-Up for 1996-2000 Honda Civic's.
Included Are: complete rear trailing arms, Rotors, Calipers, And Parking Brake cables
can you tell me if thats all thats needed.. and of course im gonna buy new trailing arm bushings...
Re: SI Rear Disc Brake Conversion (Civic98KH)
Probably going to want to buy a bigger Brake MC, and a 4040 prop valve.
When i did my rear brake conversion, i went with a GSR 1" MC, and the prop valve off of it.
be professional
Re: (JDMFantasy2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic98KH »</TD></TR><TR><TD CLASS="quote">i found an entire assembly for 380.00 ... now this is what i get with it...
can you tell me if thats all thats needed.. and of course im gonna buy new trailing arm bushings...</TD></TR></TABLE>
That's way too much money.
You can pull them from older cars for much much less.
In addition to the items you listed, you will also need the rear soft lines for calipers (the fittings are different from those for wheel cylinders) and you should also source the correct proportioning valve for your application (which depends on front brakes and chassis as well as rear brakes).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFantasy2k »</TD></TR><TR><TD CLASS="quote">yeah 380 is rape. Prop valve is a must, and a 15/16" bb/mc combo will make it feel just like an Si. </TD></TR></TABLE>
The '99-00 Si has a 7/8" master cylinder.
Regardless, a master cylinder change is absolutely unecessary for a rear disc conversion.
Re: (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
Regardless, a master cylinder change is absolutely unecessary for a rear disc conversion.</TD></TR></TABLE>
whoops my bad, i got my mc off a Sir and that's 15/16". It may not be necessary, but if you have the ability to do it, then it's a good time to do it since you need to bleed the brakes anyway.
Ek9andyroo
09-09-2009 12:42 AM
Mr. Choi
25
10-02-2004 09:03 AM
Excelerate
03-22-2004 01:42 PM
