Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Engine Light & VTM-4 lights
Old Apr 29, 2018 | 10:08 AM
LRS3326's Avatar
Default Engine Light & VTM-4 lights
The engine light came on in my 2006 Honda Ridgeline after I start it and begin driving. Shortly thereaftter the VTM-4 light also comes on and I can't turn it off. Other than that, the truck seems to be running fine. Any idea what's going on with it?
Old Apr 30, 2018 | 09:44 AM
somick's Avatar
Default Re: Engine Light & VTM-4 lights
We recently had the similar thread. Try to search for it.
How long ago have you replaced the VTM-4 fluid?
Good luck,
Sam
Old May 3, 2018 | 04:18 AM
miked19's Avatar
Similar thing happened to me this morning my 2006 Ridgeline. I was driving on my way to work then my check engine light and VTM-4 light went on. When I got to work, I parked my car, turned off my engine, installed my ODB-II reader and started the engine back up. The VTM-4 light turned off but got a P2631 check engine light code. Code P2631 is set by the PCM when the O2 Sensor Pumping Current Trim Circuit for Bank 2 Sensor 1 is sending a higher voltage signal than normal. Bank 2 is the bank of the engine that does not contain cylinder #1. It could be just an intermittent failure. Just clear the code and see if it happens again.
hawjboieg6civic
Jul 4, 2010 03:08 PM
ryanminer
Oct 17, 2008 08:52 AM
hkhaperey
Apr 30, 2007 07:15 AM
eg686
Apr 18, 2003 01:01 PM
ITR624
Feb 27, 2003 09:25 PM
