H22a4 Head On H22a block
Old Mar 20, 2018 | 08:54 PM
Inmate's Avatar
Default H22a4 Head On H22a block
I got my Prelude 2001 engine swap last year from a mechanic. Looking at the block, it is H22a4 head on H22a block [I think the bottom is from a Honda Accord SIR]. When I started driving last year, the engine light came on.
This year I brought it back because I need an emission test. He could not fix it and said something is wrong with the EVAP.
Brought it to the dealership and after two days of checking, they said it's the ecu.
Did this swap ruined my ecu? What ecu should I get? HELP
Old Mar 20, 2018 | 09:35 PM
TimiK's Avatar
10 Year Member
Default Re: H22a4 Head On H22a block
you dont know what parts the guy changed from previous engine?
you cannot mix usdm vs jdm electrics then engine light is on because the electrics are little bit different
what code youre getting?
Old Mar 21, 2018 | 03:23 AM
Inmate's Avatar
The dealership said something was wrong with the EVAP by using the Obd2 scanners, but they checked everything and said ecu was getting power but couldn’t process code. Basically they’ve saying ecu.
What should I do?
Old Mar 21, 2018 | 04:01 AM
TimiK's Avatar
10 Year Member
find a someone who knows what hes doing and check the code - or then try to find out what sensors there is now, which ecu and which block
no one can help you without better info...
dealerships dont usually know c-rap about engine swapping if mixing jdm/usdm parts so if theres mixed usdm/jdm parts/electrics which wont work together they dont have a clue
your mechanic is the key here who did the swap
Civic Racer X 7
Jun 27, 2016 08:14 PM
Dr.green
May 6, 2009 12:10 AM
i8umup
Jul 24, 2008 01:36 PM
Subwarrior
Jan 12, 2005 06:35 PM
