1992 Civic GSR Swap Tach Not Working
Old Mar 19, 2018 | 09:15 AM
epingquian's Avatar
Default 1992 Civic GSR Swap Tach Not Working
Anyone know what could the reason be why my tachometer isn't working after dropping in my OBD2B GSR swap?
I've read that I might have to jump the wire from the distributor to the wire on the driver side where the harnesses plug in?
I used everything from the GSR swap, distributer, engine harness etc.
Can anyone confirm that or help me out please?!
Its my first time doing a project this big so please don't bash on me LOL
Old Mar 19, 2018 | 10:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 1992 Civic GSR Swap Tach Not Working
Does your distributor have the blue tach signal wire ??? Eight wires in the plug does NOT have the tach wire... nine wires in the plug does have the tach wire. If not, you will need to get an older distributor that has this wire. Now, since you also used the newer GSR engine harness, you will need to add a wire from the distributor to the chassis harness plug at the shock tower so that it sees the rpm signal. Then your tach will work.
Old Mar 29, 2018 | 08:29 AM
epingquian's Avatar
Forgot to reply to your response! Got it to work like this and just gotta the wire in nicely now.
Dekorum
19
May 29, 2010 07:42 PM
4dooreg-k
11
Jun 23, 2006 12:50 PM
nonvtec
Apr 5, 2005 11:11 AM
YellowCRXSi
Jul 12, 2004 09:55 PM
serious
Jan 22, 2003 11:21 PM
