EK J-series mount question
Can anyone tell me if Hasport's mounts for a J30A4 engine and transmission will fit a J37A4 engine and transmission?
Also, can the clutch cases (bellhousings) be swapped directly between the transmissions?
yes the mounts do bolt up but the back bracket requires modification to accept bigger bolts
the J37A4 also requires use of 09 up TL manual transmission as the bell housing is different
with that being said all the guts of the J37 would swap into your J30
So the guts swap right over? Wow! What about just the J37 bell-housing? Will it swap with the Accord J30 bell-housing? I looked at pics as best as I could from Honda websites comparing the 2, but I just can’t tell.
s14swap240sx
Mar 6, 2010 06:18 AM
trooper0641
Oct 12, 2009 02:54 PM
