VTEC not engaging DPFI to MPFI
Old Feb 28, 2018 | 03:01 PM
hondacurious's Avatar
Default VTEC not engaging DPFI to MPFI
Swapped a b20v into crx, DPFI now mpfi, obd1 ecu with hondata s300, obd2a dizzy, no knock sensor, vtec pressure switch delete. Car is running smoothly and no idle issues since i changed tps, question is VTEC not engaging. No cel. Engine was in 96 hatch before and vtec had worked fine a few years ago. What Ive checked, resistance in vtec solenoid: good, no opens or short from solenoid to ecu vtec solenoid or vtec pressure switch. No burnt or damaged areas in ecu. So Im stuck on what to do next or to even check? Dizzy, dizzy wiring, would that affect the signal to engage vtec. Only thing ive noticed is when i floor the car sometimes not always, the tach has a skip for a slight second. When I say skip not in acceleration but seen on tach
rsfire
Engine Management and Tuning
Oct 28, 2017 06:27 AM
Kova23
Oct 15, 2012 11:25 AM
scottypippen147
Nov 16, 2010 03:35 PM
b19coupe
Sep 3, 2003 07:02 PM
flat-blk-HB
16
Sep 30, 2002 07:04 PM
