Brake lights stay on when car is off?
I replaced the brake light switch as they are pretty common to go bad.
Its a 1993 Del Sol S, non ABS.
Any other ideas on what to check?
But, isn't the switch able to be adjusted closer to the brake arm? My plastic part on the brake arm broke (22yrs old) so I am using the penny trick, until I can put a small bolt through the hole, and adjust the switch to a new position.
The piece that goes into the brake pedal itself was missing. Attached a penny to cover the hole.
babybreese
Aug 16, 2017 12:33 PM
91efbluehatch
Jan 30, 2011 12:56 PM
