99 Civic Si Sunroof relay causing fuse 51 to blow
Hey there, Honda tech peeps. I'm working on this 99 si. I first found the sunroof mirrors and door locks not working. Looked at fuse 16 changed it got the mirrors working.
then searched how to see why the door locks and sunroof were not working. Found a good test on here unplug all actuators and then plug in to see what causes the fuse to go.
Door locks work fine.
when I plug everything in for the sunroof is when I have an issue. The sunroof relay is causing the fuse to blow.
if I leave the sunroof relays unplugged the locks still work cause the fuse is still good.
any ideas or help would be good. I don't think the relay is bad but could the relay itself cause the fuse to blow or is there a short in the line some where. I'll continue to search I don't see any nicks in the line
thanks in advanced
thanks in advanced
Short may possibly be at the open/close switch or the tilt/close switch (both are located on the underside of the roof). You can remove the headliner cover and unplug the 4-Gray connector to those switches and see if the fuse still blows.
Those switches are part of the moonroof/sunroof cable assembly.
Ended up being the relay.
the previous azz hat jammed the relay in wrong
causing the middle prong to short the relay.
was able to pull it out and get the relay back to working condition
which in turn has the sunroof working again.
Thanks for the help. Hopefully this will help someone else in the future.
thanks in advanced
thanks in advanced
hans stoner
Oct 2, 2006 06:11 AM
