Buy OEM or third party? 95 Civic Trailing Arm Bushings
Old Feb 8, 2018 | 12:12 PM
Jon Petersen's Avatar
Default Buy OEM or third party? 95 Civic Trailing Arm Bushings
I bought some rear trailing arm bushings for my 95 Civic EX online for $35. If I were to go with the Honda ones, it would have been more than $80. But now, I'm not so sure about the quality of these bushings (there are holes in them already, and they don't look like they're the same length as each other) and I would rather have good, expensive bushings than cheap, bad ones. That being said, if these bushings will work, I'm more than happy to save some cash. Thanks for the help, friends.
Old Feb 8, 2018 | 06:58 PM
sjg88's Avatar
5 Year Member
Default Re: Buy OEM or third party? 95 Civic Trailing Arm Bushings
i think you'll be okay
as long as the rubber is still in good shape and not cracked or dry rotted you should be fine.
Old Feb 8, 2018 | 07:37 PM
Would you consider this cracked? I saw Engineering Explained do this job and it looked like his new bushings had the same tear through the sides, like on the right in the picture.
Old Feb 8, 2018 | 07:41 PM
sjg88's Avatar
5 Year Member
yea i think thats normal...if the main pillars (where its stamped GSR..were cracked..id say they were no good)
The trailing arm bushings on my integra track beater have about 200K miles on them and are trashed and they look way worse than this.
Old Feb 8, 2018 | 07:44 PM
S2k@9K's Avatar
It's normal. There's supposed to be space there to allow movement of the bushing. That's actually just a little rubber left over from the mold.
Thanks man. I'll put em in and tell you how it goes.
Old Feb 11, 2018 | 09:38 AM
So I tried putting those in and they didn't fit. Ended up bending one. Turns out the outside needs to be beveled in order to slip in correctly. So I went to AutoZone and bought real ones that fit. I got a question, the passenger side bushing didn't go in symmetrically (the front part sticks out a little farther than the back part) but I got it to for back in. This doesn't seem like a big deal to me, and I really don't want to do it again. Should it be alright a little asymmetrical, or is it a surprise concern that needs to be fixed right away? Thanks.
Old Feb 11, 2018 | 10:35 AM
tony_2018's Avatar
Fish Twig
Define real? I mean the 1st one you bought were real, you held them in your hand. Right?
Old Feb 11, 2018 | 11:15 AM
Haha, yeah, the first ones were real, they just didn't fit. The ones I bought were real in that they actually fit, they weren't crap ones like the first pair.
Ej2guy28
Aug 6, 2012 09:22 AM
aimbot
Apr 22, 2011 06:30 AM
SlammedEG6
10
Feb 4, 2010 11:42 PM
Scottyk6
Suspension & Brakes
Jan 17, 2008 04:08 PM
effects66
Jul 13, 2005 10:34 PM
