how do i unlock a transmission thats locked in park?
2000 honda civic 4 dr gearshift was working changed battery and wont shift out of park without me unlocking it ..brake lights work car moves slow in d4.
Check the battery cables and terminals to ensure no corrosion, cable wires frays, and tight connections. If necessary, remove battery cables, clean cable terminal with a wire brush or something, and reconnect. Generally, negative battery cable should be removed first and re-installed last.
You would need testing tools like a multi-meter to do some diagnosis; checking voltage and continuity at wires, fuses, components, etc.
Alternative is to have someone with some testing tools and automotive knowledge to check for you.
Check the battery connections (visually, etc.). Make sure the cable connector is pushed down all the way on the battery terminal and properly tightened. If that is the cause, the issues will go away.
A 10mm wrench or adjustable wrench is all that is needed for the battery cable connectors.
quetzalcoatl
Oct 1, 2009 02:55 PM
