Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
MIL after VTEC Swap
Old Jan 30, 2018 | 12:12 AM
Kal Ironfist's Avatar
Default MIL after VTEC Swap
Hello all, I have a 2005 Civic LX and have a technical question. Forgive the lengthy post, but I wanted to provide as much info as possible. So, after 240k miles, I replaced the motor with a jspec Motor. The one I was sent was a vtec motor. After some research On how to get the vtec to function, I purchased a junkyard PCM from a 2002 EX model. I had the immobilized programmed so the car starts. I added the two wires to connector B to my existing PCM harness to activate the vtec solenoid and to the oil pressure sensor for the vtec. The vtec works great. I do have a check engine light for DTC P0135. Checking the wiring diagram for the LX and EX models, it appears I also need to add two wires to another connector for the HO2S element. Is this correct? Do I need to get a different sensor (for an EX model I assume)? Any help is appreciated. Thanks!
Old Jan 30, 2018 | 01:51 PM
holmesnmanny's Avatar
Default Re: MIL after VTEC Swap
normally the jdm motors don't have the vtec pressure switch, you have to swap it over from the old to the new, but since you don't have one you have to purchase one separately or source one separately from a junkyard
Old Jan 30, 2018 | 07:55 PM
My motor came with the Vtech solenoid on the back of the head, but it did not come with the oil pressure solenoid. I picked up on of those with the EX PCM from Pick A Part and wired it in. The vtec works great. My concern was about the MIL for P0135. I believe I might need to rewire the O2 sensor to different pins to get it to function properly. Do you know if this is correct?
Old Jan 30, 2018 | 09:13 PM
The lx and ex models have the oxygen sensors in different spots. On the ex they are combined with the cat in the downpipe while the lx has them in the exhaust manifold with the cat.
Are you sure you are still running both oxygen sensors to begin with ?
Old Jan 31, 2018 | 08:16 AM
Both oxygen sensors are still physically in the manifold and connected to their harnesses. As for if they’re both functioning, that I’m not sure. The MIL came on instantly for P0135, but now that the car has some miles on it, it’s entirely possible there are more codes for O2 related problems. I’ll scan it again tonight.
Old Jan 31, 2018 | 12:28 PM
it looks like they use different sensors so it's possible the pins are different, i don't know if you simply swapped over your existing manifold to the new engine
Old Jan 31, 2018 | 12:37 PM
I used The LX exhaust on the new motor. I had it and it was cheaper and easier than swapping to the EX exhaust. I can check the salvage yard for everything but the cat. I’ll check into it this evening and start by seeing if I have new DTCs.
Old Jan 31, 2018 | 06:13 PM
Ok, I only have the one DTC, P0135 B1S1 O2 Heater. Backprobing the wires on the upstream O2 sensor, I am not getting power or ground to the heater element. I think the problem is I have a 2005 LX with a 2003 EX PCM. The 01-03 EX was wired differently on the heater element than an 04 EX/04-05 LX. Does anyone have a wiring diagram for the upstream O2 sensor for both the 03 EX and 05 LX? Thanks.
D16y8VtecRunner
43
May 11, 2014 09:36 AM
Fireman.142
Aug 1, 2010 09:07 AM
tankizk
Jul 13, 2007 04:37 PM
Shake and Bake
14
Jan 3, 2006 06:20 PM
AIWFCIATR
Jul 23, 2004 12:11 AM
