2001 accord P0128 code
Old Jan 28, 2018 | 02:41 PM
emtdivr7's Avatar
Default 2001 accord P0128 code
my 2001 4 cyl ck eng lite is on showing Code P0128 coolant/thermostat. I replaced thermostat and 2 sensors and light comes on again. any suggestions?
Old Jan 28, 2018 | 08:10 PM
2001GSRSC's Avatar
5 Year Member
Default Re: 2001 accord P0128 code
Thermostat under the outlet has no connector to the ecm. The water outlet has the CTS.
2 sensors? The coolant temp sensor(but not a 0128)? Fan switch? When you ohm it out what are you getting?
There could be an open in the harness wires. Make sure the fans are operating properly. That the radiator is not clogged up, and has proper level coolant with overflow reservoir in closed system.
Old Jan 28, 2018 | 11:02 PM
holmesnmanny's Avatar
underneath the distributor is a two pin sensor, test it for ohms when the car is completely cold, it should be between 2000-3000 ohms. Test it again after warming the car completely up. Should now be 150-250 ohms or so
Will32283
Dec 12, 2017 01:09 PM
jasrams
Honda Civic (2001 - 2005)
Jun 6, 2011 04:40 AM
nsxracer79
Oct 25, 2008 02:03 PM
sacredc0w69
Jun 5, 2003 02:03 PM
