Honda CR-V & Element 2WD & 4WD Element & CR-V
2008 Honda Element Air Condtioning Issue
Old Jan 23, 2018 | 08:37 AM
goherd1549's Avatar
Default 2008 Honda Element Air Condtioning Issue
I have a 2008 Element LX FWD. About 3 years ago I began having issues with my blower motor on the ac. It would randomly just stop blowing. I had the motor replaced at the dealership and recently the issue has started again but this time accompanied by another problem. Currently the blower will sometimes not engage when turned on. At times, it will just begin blowing on its own. Other times it will begin to blow after hitting a hole or a bump. Most recently the cooling part of the ac has followed suit. Sometimes it engages and other times it does not. It generally works at higher speeds but not always. Recently had a two day period where the ac did not work at all. It is now back to working. Last time I had it checked, nothing could be found. Any suggestions of what could be causing this issue?
I have read some articles about relays going bad but would that explain the off again on again working or the blower motor issue?
Thanks in advance.
Old Jan 23, 2018 | 08:50 AM
BigBerz's Avatar
Default Re: 2008 Honda Element Air Condtioning Issue
That sounds like a connection problem somewhere. If things are going off and on when hitting bumps it's either relay or wiring. The fact it blows on it's own while not being turned on is curious. Finding wiring gremlins is a bitch and very time consuming.
Berz out.
Old Jan 23, 2018 | 01:31 PM
goherd1549's Avatar
I think I worded my first post incorrectly. The blower comes on randomly if it is set to on. It never comes on in the off position.
Old Jan 23, 2018 | 02:06 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Issue can be due to a failing/failed blower motor power transistor.
1. Locate the blower power transistor under the passenger dash.
2. Unplug the electrical connector to the transistor unit.
3. Attach a jumper wire (short piece of wire) from the Blue/Black wire cavity to the Black wire cavity on the unplugged electrical connector. Leave the connector unplugged.
4. Turn the ignition ON.
Does the motor run?
carp_5
Acura TSX
May 26, 2019 02:11 PM
kpjo4
Aug 3, 2009 05:47 PM
Tip14
Jun 17, 2008 01:41 PM
mymeatb18"
Jun 10, 2006 03:11 PM
j.Ngo
Apr 23, 2004 08:27 PM
