1996 Honda Civic, speedometer and RPM’s not working
Old Jan 6, 2018 | 11:12 PM
Sam19's Avatar
Default 1996 Honda Civic, speedometer and RPM’s not working
hey guys, I’m having trouble with my cluster and I’m not sure wats wrong. I picked up a new one but for and auto but my car is a standard so could that be a issue too? It reads my fuel and temp but not those 2. My old cluster does the same thing and I’m not sure wat the issue is. Anyone know wat it could be?
Old Jan 7, 2018 | 03:58 AM
Megalodong's Avatar
Default Re: 1996 Honda Civic, speedometer and RPM’s not working
Pull the VSS Variable Speed Sensor and inspect the splines..they may be stripped. Spin it by hand and see if both gears turn.
Old Jan 10, 2018 | 01:33 PM
Sam19's Avatar
I just check it and the splines looked fine and I cleaned it it all off. Nothing has changed, I still don’t get my rpm’s and mph.. when I was cleaning off the vss I noticed a little corrosion but I cleaned it off.
Old Jan 10, 2018 | 05:32 PM
jonsey1886's Avatar
10 Year Member
Check for fuse 15 in the under-dash fuse box. Is it blown? If yes a quick search of the FAQ page for "Fuse 15 TSB" will help you fix the issue.
Old Jan 10, 2018 | 07:53 PM
Sam19's Avatar
The fuse isn’t blown /:
Old Jan 10, 2018 | 09:35 PM
Megalodong's Avatar
Seem like it's most likely related to the cluster you purchased? If you pull a manual cluster at a junkyard might as well pull a VSS from the same car and try it (match it up with the current one first though).
Old Jan 11, 2018 | 07:02 AM
Sam19's Avatar
I’ll hopefully do that this weekend, this **** is annoying af... when I got the car aftermarket Tachometer was installed but I removed it immediately and I noticed that my blue wire doesn’t have the black pill? I can’t find the pill anywheres online and idk what the real name for it is.. could that be another issue?
Old Jul 2, 2018 | 12:05 PM
oniboshi's Avatar
hello
i need electrical schema for honda civic 93
it have problem. the rpm not work. i thing the problem is in the connection or wires because a mecanical worker has fix some problems in the car
please help me
Old Jul 2, 2018 | 01:07 PM
thewrai6th's Avatar
Originally Posted by oniboshi
hello
please help me
Google 1992-1995 civic shop manual pdf H0ndaH00kUp. It's out there for sure. Good luck!
Old Jul 3, 2018 | 02:48 PM
oniboshi's Avatar
thank you very much
2001whitecrv
Honda CR-V & Element
Oct 19, 2017 05:45 PM
parisz47
Apr 11, 2017 05:02 AM
agustintorre
Sep 14, 2012 06:55 PM
pacey
12
Aug 18, 2009 11:24 PM
88aeFC3S
Aug 4, 2008 12:41 PM
