VSS fuse?
Old 04-10-2017, 02:51 PM
parisz47's Avatar
Default VSS fuse?
Im working on my VSS ,but I need to check the fuse, what fuse would it be/ and where in the fuse box does it go?
Old 04-11-2017, 03:05 AM
Txdragon's Avatar
Default Re: VSS fuse?
If that particular fuse were blown, your car would not start.
the following link is a comprehensive guide to troubleshoot your VSS, use it and be victorious!
VSS - Vehicle Speed Sensor Troubleshoot, Repair, Replace - How To.
I struggled for a long time through this to find out I needed a new cluster. If you've replaced your VSS already and you're still having problems and have NO cel, chances are that you probably just need a cluster as well. Lol.. Either way, this link will help you figure **** out.
Old 04-11-2017, 05:02 AM
mk378's Avatar
If your Civic is a 1996 to 2000, you should search on the "Fuse 15 Problem."
The fuse involved there is of course #15 under the dash. With the fuse blown, the car will still run, but the speedometer does not work, several CEL codes are thrown, and the voltage from the alternator varies causing all the lights on the car to flicker.
Luiz_aka29
12
08-15-2009 08:56 PM
Syndacate
84
11-23-2006 07:38 PM
sir2sol
08-12-2005 09:02 AM
GreenD16Y8
08-08-2005 03:59 PM
delsolcrazy
05-05-2005 03:06 PM
Quick Reply: VSS fuse?
