01 Prelude ecu/smog issues - CALIFORNIA
ok the 20year old son did a few stupids here!
90k miles on this pretty Lude! Runs awesome... but>>>
Auto trans started to slip. My son had a chop shop drop a 5-speed in it. Loses his ONLY CHIPPED KEY for the car. Chop shop hard wires ignition direct to starter bypassing immobilizer.
Swapped out orig OBD II ecu for OBD I to get it to work correctly. Then a mis-shift, blows the H22 engine. and swaps it for a JDM H23 blue top.
OBD II got sold off. (getting good here)
Since it was parked "non-operable" CAL DMV requires STAR Smog to re-register. Surprise?
he needs a midnight smog - but needs the OBD II to get it done. - SUGGESTIONS? is this OBD II for 01 Prelude agnostic? or does it have a VIN burned on it.
u should be able to de solder the auto feature on the 0bd2 ecu i did that on mine and was able to keep immobilizer etc.. passes smoke like OEM
Thx and Happy New Year Hatch - however, as I wrote, he no longer has his original OBD II ecu.
He now has an OBD I. And no master key to reprogram a used OBD II.
thoughts?
thoughts?
about using H22A4 ecu with H23V:
Originally Posted by Prelude1897
This type of swap has been done several times and plenty of threads about it, cause I've actually done thus swap for several people. I hope you still have your original ecu. Here's a list of what you needed to swap from your old motor to this motor in order to keep it all as if it came in the car factory
-intake manifold
-dizzy
-ignition coil
-oil pump
-crank sensors
-motor harness
No need for any extra wiring or special ecu. If you swapped these parts over, car would run normal.
-intake manifold
-dizzy
-ignition coil
-oil pump
-crank sensors
-motor harness
So one of my MOST IMPORTANT QUESTIONS to the forum is:
Is the 01 Prelude OBD II ECU hard burned with the VIN# - OR -
Can I hunt for any used Honda 2001 OBD II? - IF I can, does the ECU have to be PRELUDE-H22 specific?
Thanks TimiK
Here's the ECU I found recommended my 2001 Prelude H22 automatic trans
https://www.ebay.com/itm/97-01-Honda-Prelude-OEM-Ecu-Engine-computer-ECM-A-T-Part-37820-P5M-L55-/201649419944?fits=Model%3APrelude
Is the 01 Prelude OBD II ECU hard burned with the VIN#?
a
a
Thx LiteraCola!!
My '01 lude is a "California car"... so its ECU shouldn't be different from any other in the U.S.
Is that a safe assumption?
If anyone on the forum would like to confirm before I go and BUY ONE ...please do so!!!
Just for my own knowledge... so would that be the P5P ecu? I know the auto ECU is the P5M, but i can't find much more information than that.
37820-P5M-L55
restoring the car back to factory auto trans.
just wanted to confirm LiteraCola's assertion that the VIN is NOT HARD CODED on this ecu.
nesluopetan
Jun 14, 2007 12:23 PM
hondaguyexsi
Jul 15, 2005 09:49 AM
