B16A2 - Stalls when cold
Ok, so I've been seeing some strange behaviour coming from my engine ever since I had the valves adjusted because of idle problems (IACV, FITV and pretty much every sensor in the car has been checked and replaced when necessary).
The engine fires up with no fuss at all. The fast idle valve opens up and the revs stay around 1200RPM and as the car warms up the idle RPM drops as expected. However this whole process takes around 5 minutes and trying to move the car before it ends is impossible because it stalls like crazy.
After the engine warms up, it gives me no problems at all.
To sum it up, I'd like some advice on what could be the problem because going out in an emergency is absolutely impossible and I fear such scenario.
Have you already checked/replaced the TPS? I would also take the intake off of the throttle body and move the cable back/forth, just to make sure the plate is working as it should and isn't doing any sort of sticking/seizing.
Changed it last week because the car was jerky at constant speeds and when taking off at 1st gear. Installed it correctly and now the engine responds beautifully. The sensors are all in pretty good shape (but some are 20+ yo, so could be faulty). My trusty Honda mechanic felt like it and revised the throttle body and the whole intake when he adjusted the valves, but he's made mistakes before, so I'll check it out by myself.
meanshyguy
Oct 24, 2007 12:49 PM
lsxtreme81
Apr 20, 2007 05:39 PM
