Christmas idle issues
Old Dec 25, 2017 | 09:32 AM
ratchetEDsedan's Avatar
Default Christmas idle issues
Hey all, merry christmas.
My Del Sol has been doing some weird stuff.
1. Idles fine on start/cold idle.
2. When it warms and idle drops, it'll misfire randomly, with varying severity, and some times die completely. Sometimes it'll idle fine for five minutes, and just putt once or twice, some times it'll choke and recover, sometimes it'll choke and die.
3. Doesn't surge/hunt at all.
4. On power for the most part it runs fine, sometimes at low rpm/high load, it'll cut out once or twice but that's it.
5. Already swapped plug wires for some NGKs I had laying around.
I suspect a spark issue but I haven't heard of ICMs or coils having intermittent issues like this.
Sticky injector?
Old Dec 25, 2017 | 09:47 AM
austen95's Avatar
Default Re: Christmas idle issues
Sticky injector?
What year Del Sol? Engine size? Any mods?
Old Dec 25, 2017 | 10:00 AM
mk378's Avatar
Do a valve adjustment. Inspect the spark plugs for one that looks different from the others, indicating the problem is at that cylinder rather than generalized.
Old Dec 25, 2017 | 10:04 AM
93 Si, D16z6, and nope, completely stock. Has a different set of stock injectors, new cap and rotor like 6 months ago.
Old Dec 25, 2017 | 10:08 AM
I feel that it's worth noting that I had another civic that ran on three cylinders just fine and never died, so I don't see it being an individual cylinder. Whacky valve lash wouldn't cause a constant problem? Valvetrain is super quiet as well.
Old Dec 25, 2017 | 10:26 AM
austen95's Avatar
I would ohm the injectors out and make sure that none of them are fried. The should all be sitting between 10-13Ohms. I’d also check for any vacuum leaks since the issue only happens when the engine is warm I would suspect that the metal is expanding and causing a pretty good vacuum leak if that was it. I worked on an Integra that had crazy vacuum leaks when the engine got warm but ran perfect when it was cold. We ended up retorquing the intake bolts, putting new injector seals in it, and finally a new FITV
Old Dec 25, 2017 | 10:34 AM
Now there's a good thought. I know the injector seals are good because that's why I swapped the injectors haha. They were spraying fuel all over the bay under pressure so I swapped O rings. I'm gonna go check out vacuum right now.
Old Dec 25, 2017 | 10:37 AM
austen95's Avatar
Ya my injector seals were super bad to at one point lol. I couldn’t figure out where the gas smell was coming from in my car and figured I would find it once it got worse. Needless to say after I threw up from the smell being so strong I made it my priority to find the cause
Old Dec 25, 2017 | 10:54 AM
I think I may have found it, I was spraying water on everything, and where the IACV bolts up in the back, there was a place where it should have been pooling up and it looked like it was getting sucked into the crack. I'll order a new gasket and see what happens.
Old Dec 25, 2017 | 01:42 PM
austen95's Avatar
Awesome! I hope the new gasket fixes it! Give me a heads up if it works
tgordenDELSOL
Oct 12, 2014 11:26 AM
thebleek
Nov 23, 2008 09:04 PM
lv6l
14
Nov 28, 2005 06:50 PM
pdiddy
Dec 10, 2002 10:47 PM
