Troubleshooting: B-series turbo application hitting boost cut at 3,000RPM
Old Dec 4, 2017 | 05:44 AM
Kamryn Vasquez's Avatar
Default Troubleshooting: B-series turbo application hitting boost cut at 3,000RPM
HAving an issue with a turbo b series the car cuts out around 3k like it hits boost cut but isn’t injectors seem like they just stop working
Old Dec 5, 2017 | 05:05 AM
DumpdEJ6's Avatar
I like the tuna here
Default re: Troubleshooting: B-series turbo application hitting boost cut at 3,000RPM
I don't have anything helpful to say as I don't do my own tuning, but I love the file name, lmao. Good luck with getting it figured out.
Old Dec 5, 2017 | 07:53 AM
turbomaniac's Avatar
I am not sure what this could be but i will give some possible issues to look into; could it be hyper- over boosting? Seems its like extremely lean, or cut from map sensor. What kind of map have you got? stock? could it be wrong mapping at the specific rpms and high load? (ie 0% duty cycle at high load (100%) at 2500-4000rpm?
Old Mar 23, 2018 | 07:41 PM
Xax's Avatar
Xax
Default Re: Troubleshooting: B-series turbo application hitting boost cut at 3,000RPM
clicked this thread to ask exactly this.. hard to diagnose anything without these questions answered
Old Mar 23, 2018 | 10:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
It could be a "Protection" issue as well... check the A/F value and time delay and see if that corresponds to the "cut" you see in the datalog above.
Old Mar 25, 2018 | 07:59 AM
motoxxxman's Avatar
rpm: 2980 (obviously not idle)
MAP: 7"/hg of vacuum (means you are holding throttle open, not closed throttle)
TPS: 0% (indicates closed throttle, but according to the above, you obviously aren't at closed throttle)
Your tps sensor is either dead, or not adjusted correctly, or not installed correctly.
Old Mar 25, 2018 | 04:27 PM
theYBLEGAL's Avatar
Loved
Share your calibration file on Dropbox or something for us
Old Mar 25, 2018 | 07:20 PM
motoxxxman's Avatar
he doesn't need to. It has absolutely nothing to do with the problem. The proof is dead obvious in the screenshot he posted. Read my comment above yours.
Besides, this thread was revived from last december, and the OP hasn't posted since. Probably because he fixed the TPS and didn't need to come back here
Old Mar 26, 2018 | 10:26 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I agree with motoxxxman... the TPS value for the entire datalog is 0% or certainly very close to zero. Fixing the TPS likely solved the issue. Good eye motoxxxman
krugozor
Feb 21, 2011 08:38 PM
H-allmotorda9
Feb 7, 2010 07:29 PM
vy3tnamezz
Sep 1, 2009 07:10 PM
rdssk8rcs1
Oct 10, 2006 06:43 AM
B16Civic93
Apr 2, 2005 09:39 AM
