Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 civic obd II issues HELP!!
Old Nov 25, 2017 | 03:44 PM
jimgorb's Avatar
Icon6 2005 civic obd II issues HELP!!
i have a check engine light on my car, the OBD II wont read with a plug in computer, car runs like crap since the light came on. how can i see what the code is?
the car lost power, the temp gauge stopped working, and the auto transmission wont shift up or down unless i manually change the gears up or down.... frustrated. 1.7 engine
Old Nov 26, 2017 | 04:03 AM
toyomatt84's Avatar
Sanji
Default Re: 2005 civic obd II issues HELP!!
Sounds like your ECU may be dead.
Old Nov 26, 2017 | 06:07 AM
thetut's Avatar
Before you replace the ECU, make sure that the alternator mounting bolts are tightened to spec.
Old Nov 26, 2017 | 09:01 AM
jimgorb's Avatar
thank you, ill check on those things and get back to you
Old Dec 5, 2017 | 11:38 AM
jimgorb's Avatar
UPDATE...... Yes the ECU was fried, The Alternator bolt was loose. I bought a used ECU from wrecking yard, had it flashed, done! Drives great again.
my original ECU numbers ended in a 76, found out that numbers from 72, 73, 74, 75, and 76 all will work. Thank you guys for your dead on diagnostic answers.
Old Dec 5, 2017 | 06:22 PM
toyomatt84's Avatar
Sanji
Glad to hear it worked out for you!
bub113
Dec 22, 2008 04:26 PM
gsrboost
Apr 16, 2005 08:51 PM
88turdbucket
May 25, 2003 06:45 PM
hybridb18
Mar 29, 2003 09:12 PM
Norcalstoppy
Jul 11, 2002 06:26 AM
