TX 1995 Integra GS-R 392whp FS
I bought this car from backroadCR-V on October 3rd. After evaluating my reason for purchasing this car (wanting to track), I've come to realize I need to focus on my family and my business before pleasure.
I bought it for $6,000 and am asking $6200 to recoup what I spent flying to Arkansas to get the car. I won't make a dime on it. Open to trades for a nice 4-door Teg, 4-door 96-00 Civic, or 4-door Si 06+.
1995 Integra GS-R Turbo. 392whp. 232k original miles.
https://honda-tech.com/…/backroadcr-vs-high-mileage-b18c1-…/ < Build thread.
Very Clean and Strait. Full Interior with Power Steering & Cold AC. Excellent Interior Condition.
Stock B18c1 (Very good Compression)
CTR/ITR Cams
Skunk2 Pro Manifold
ITR Throttle Body
Crankcase Vents & Catch-can
All New Motor Mounts w/ Poly Torque Mounts
6lb Race Battery
MyHondaHabit Oil Pan Stud & Gasket
Stock GSR Transmission (no Grinds)
Competition Stg4 Clutch
Competition 12lb Flywheel
K-Tuned Shifter
New OEM Shift Linkage
All New OEM Shifter Bushings
AutoWorks Street X Turbo kit
Garrett GTX2867R Turbo
2000' Deg Coated Manifold & Turbine Housing
Tial MVS Wastegate
Tial 50mm BOV
3" Downpipe w/ Recirculated Wastegate Pipe
3" Turbo Back Exhuast
Front Mount Intercooler with 2.5" pipes
Custom Sheet Metal Cold Air Box
Slim cooling Fans
Walbro 255 in-Tank Fuel Pump.
New fuel filter
Fuel Pressure Gauge
Grams 750cc Injectors
Blox Fuel Pressure Regulator
Hondata S300 V3 in GSR P72 ECU
PLX Wideband o2 with Touch Screen Gauge
Autometer Boost Gauge.
Hondata/Omni 4bar Map Sensor
New OEM Knock Sensor
New Nitto 205/50-15 Neo Gens (all 4)
Eibach Springs 1.7" drop
Tokico Illumina Adjustable Front Shocks
Tokico Blue's in the rear.
Comes with ITR brake calipers.
It's currently on a 93 tune so it's pushing about 310whp on 10psi. e50 at 14-15psi will give you the 392whp.
I am the third owner of this beauty. Car has salvage title BUT it's technical, as the car doesn't have any structural damage it was only cosmetic damage. You will be hard pressed to find a better GS-R. ONLY Name brand quality parts on this car. This is no rice project. The previous owner took the time to do everything right. Lots of detail and attention into this build. It has easily more than $6k into all the aftermarket turbo parts and supporting mods, so basically you're getting a turbo kit with a free car. One of the cleanest Integras you'll find, period.
Please PM me or text me at 3187894754 for more info or to see the car.
CTR/ITR Cams
Skunk2 Pro Manifold
ITR Throttle Body
6lb Race Battery
K-Tuned Shifter
Tial MVS Wastegate
Tial 50mm BOV
Slim cooling Fans
New fuel filter
Fuel Pressure Gauge
