2001 Acura Integra GSR Tastefully Modded
Price $6000
2001 Acura Integra GSR, 5 speed manual transmission, 132k, clean title. No mechanical issues, whatsoever. Transmission shifts great with zero grinds or pop outs. The motor is extremely healthy and strong. It does not burn, smoke or leak anything. Adult owned and maintained. It is extremely clean inside and out! You will be hard pressed to find such a clean and well maintained Integra like this anywhere! Zero rust, but does have paint scrapes and chips on the front of the car. What you would expect from the car being 15 years old! Everything works! Ice cold AC/hot heat! Power everything. Full stock GSR leather in perfect condition!
The car has been tastefully modded. It's handles, turns and stops on a dime! It would make for an excellent road race or autocross project or driven as is! It handles like a dream.
New parts:
Skunk2 Intake Manifold
OmniPower 68mm TB
ITR Intake Arm
ITR Throttle Cable
ITR Valve Cover/Gasket Kit
4-2-1 Header
OEM Brake Master Cylinder (15k miles ago)
Exert Clutch Master Cylinder (17k miles ago)
Radiator
Goodridge SS Brake Lines
Type R Front Brakes (calipers and rotors) with Stoptech Performance Pads (15k miles ago)
RSX/EP3 Rear Calipers (calipers and rotors) with Stoptech Performance Pads (15k miles ago)
Koni Yellow Shocks
Ground Control Coilovers (450f/550r spring rates)
ASR rear subframe brace
Eibach 25mm Rear Sway Bar
Function7 RLCA's
Function 7 Spherical end links
Rear wiper arm delete (it looks nicer)
ITR Floor Mats
ITR Shift Boot
ITR Front Lip Paint Matched
ITR Badges
Clear turn signals
I'm sure I'm forgetting some other goodies, but you get the idea.
The bad:
Hatch must be opened with key
Rear driver side speaker doesn't sound the best
CEL for primary O2 sensor (I can prove its that and nothing more)
Driver side door panel has wrinkle
Paint chips here and there.
Was in small accident and has been repaired. Absolutely no frame damage or anything other than a dented panel happened. Was taken to Prestige Auto to be fixed. They are the best! Look them up!
The only reason I'm selling it is because I'm bought a new car and don't have the space for two race cars and a daily driver. This car is extremely reliable.
Please only email with serious offers and questions. Cash only. NO TRADES FOR CAR PARTS! I will not part the car out, so please do not ask.
New parts:
OmniPower 68mm TB
ITR Intake Arm
ITR Throttle Cable
4-2-1 Header
Radiator
Koni Yellow Shocks
Function7 RLCA's
ITR Floor Mats
ITR Shift Boot
ITR Badges
Clear turn signals
The bad:
Re: 2001 Acura Integra GSR Tastefully Modded
Yeah the last time I saw it was probably late summer on Barker ave.. You don't see nice subtle modded integras anymore.. If I didn't have to install a new roof/furnace/ac in fall I would have jumped on this in a heartbeat.
REHTE_DC2
09-08-2012 11:07 PM
