8.5:1 vs 10:1 pistons for turbo'd b18c GSR
Old Oct 25, 2017 | 01:32 PM
Pkades's Avatar
Default 8.5:1 vs 10:1 pistons for turbo'd b18c GSR
Looking for peoples opinions, pros/cons, and personal stories about different compression pistons.
I've read that no one uses 8.5:1 anymore and people stick with 10:1.
I'm planning on running high boost and am currently looking at upgrading turbo (currently running a t3t4 setup)
Thanks in advance!
Old Oct 25, 2017 | 03:19 PM
2kdrift's Avatar
Default Re: 8.5:1 vs 10:1 pistons for turbo'd b18c GSR
10:1
/end thread
Old Oct 25, 2017 | 03:28 PM
Pkades's Avatar
Originally Posted by 2kdrift
10:1
/end thread
can you explain please as to why they're better over the 8.5:1's???
Old Oct 25, 2017 | 03:42 PM
2kdrift's Avatar
Well there's no reason to run lower cr with today's technology all they will give you is a less responsive car and will make less power. Search there is plenty of info on this, seems like this question comes up about once a week
Old Oct 26, 2017 | 12:00 AM
turbomaniac's Avatar
one more vote to 10:1.
the b18 engine has low dynamic compression ratio due to high degree cam at vtec phase, so you don't want to lower it more.
Old Oct 26, 2017 | 02:27 AM
Chance EG's Avatar
Go 5:1 and run 1 million pounds of boost.
But yes, 10:1. Improvements in ECU control/tuning, more consistent fuel quality, better hardware and a general abundance of knowledge over these platforms lets us safely push the CR a fair bit further than we used to. Only yields benefits.
Old Oct 26, 2017 | 02:59 AM
2x0's Avatar
2x0
10 Year Member
If/when I do a rebuild I will be going to 10.5 or 11:1
Nothing worse than a laggy, peaky turbo car on the street....
Old Oct 26, 2017 | 04:25 AM
LightningTeg's Avatar
Community Builder
Low compression is for the birds
Old Oct 26, 2017 | 11:37 AM
Pkades's Avatar
__________________
07' FA5, DD
98' DC4, Race car
Hahahaha - what is this supposed to mean? :p
Old Oct 26, 2017 | 11:38 AM
Pkades's Avatar
Thanks everyone for your feed back - what about 9.5:1's??
Old Oct 26, 2017 | 11:57 AM
TheShodan's Avatar
Moderator
If you can go 9.5:1, you can go 10.0:1... Plain & simple
Old Oct 26, 2017 | 12:02 PM
2kdrift's Avatar
Aim for 10:1 due too differences in various areas such as head selected, amount of milling etc. Your never going to be exactly at 10:1 if you do end up a bit higher or lower such as 9:5 It's acceptable
Old Oct 26, 2017 | 08:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
9.5:1 compression is better than 8:1... 10:1 compression is better than 9.5:1. The key is you want a FLAT TOP piston and not a "laggy" dish type piston. The compression will be in the 10:1 range with a flat top piston type... unless you use a super thick head gasket or something. LOL. The compression can be altered +/- about a half point with a custom pin location... but this isn't an off-the-shelf product, so delivery times will be lengthy and replacement if you damage the pistons will also take longer.
Old Oct 26, 2017 | 11:24 PM
1HGEJ2's Avatar
10:1 if u have premium gas or e85......9:1 if u want drive low octan like low octane soup
Old Oct 27, 2017 | 01:50 AM
Pkades's Avatar
thanks for the reply bro, appreciate it.
will be running 98 pump gas (NZ)
Old Oct 27, 2017 | 01:51 AM
Pkades's Avatar
this was an awesome response, thanks heaps really do appreciate the help
Old Oct 28, 2017 | 07:34 PM
gorillaglue#4's Avatar
I was told by my local honda turbo guru not to go below 8.5. If you are going to lower it why not stoke it as well?
Old Oct 28, 2017 | 09:49 PM
ZC1.8crx's Avatar
I went 10:1 on my engine.
ralph11sec
Aug 5, 2012 03:21 PM
snaileg
Nov 8, 2006 04:11 PM
1JDMDOMINICAN
Dec 16, 2004 09:52 PM
ItalynStylion
Sep 2, 2004 12:23 AM
00TypeSH
Feb 10, 2003 02:13 PM
