8.5:1 vs 10:1 pistons for turbo'd b18c GSR
Looking for peoples opinions, pros/cons, and personal stories about different compression pistons.
I've read that no one uses 8.5:1 anymore and people stick with 10:1.
I'm planning on running high boost and am currently looking at upgrading turbo (currently running a t3t4 setup)
Thanks in advance!
Thanks in advance!
Re: 8.5:1 vs 10:1 pistons for turbo'd b18c GSR
Well there's no reason to run lower cr with today's technology all they will give you is a less responsive car and will make less power. Search there is plenty of info on this, seems like this question comes up about once a week
one more vote to 10:1.
the b18 engine has low dynamic compression ratio due to high degree cam at vtec phase, so you don't want to lower it more.
Go 5:1 and run 1 million pounds of boost.
But yes, 10:1. Improvements in ECU control/tuning, more consistent fuel quality, better hardware and a general abundance of knowledge over these platforms lets us safely push the CR a fair bit further than we used to. Only yields benefits.
If/when I do a rebuild I will be going to 10.5 or 11:1
Nothing worse than a laggy, peaky turbo car on the street....
Low compression is for the birds
__________________
07' FA5, DD
98' DC4, Race car
Hahahaha - what is this supposed to mean? :p
__________________
07' FA5, DD
98' DC4, Race car
9.5:1 compression is better than 8:1... 10:1 compression is better than 9.5:1. The key is you want a FLAT TOP piston and not a "laggy" dish type piston. The compression will be in the 10:1 range with a flat top piston type... unless you use a super thick head gasket or something. LOL. The compression can be altered +/- about a half point with a custom pin location... but this isn't an off-the-shelf product, so delivery times will be lengthy and replacement if you damage the pistons will also take longer.
