anyone used a gt2560 turbo for daily driver?
Old 10-27-2017, 11:34 PM
charosenz's Avatar
Default anyone used a gt2560 turbo for daily driver?
im looking to boost my 1.8L civic a but, and my research seems to say that a GT2560 with .60 A/R would be a good choice for a 7 lb boost.
Anyone doing this? I sure would like to hear. I am also open to other ideas.. Its a daily driver so I am only look for some slight extra help passing on the highway...
Charlie
Old 10-28-2017, 06:52 AM
Chance EG's Avatar
Default Re: anyone used a gt2560 turbo for daily driver?
Boost would be instant and a lot of fun on the low end. I'm not sure if you'd choke on the top end though, I think you may have some issues maintaining boost pressure on higher RPMs, would probably require some tweaking on the wastegate to get it right.
For a B16 I wouldn't worry quite as much about this, but for a 1.8 I'd suggest bumping up at least to a GT2860. Is this an LS motor or VTEC?
Old 10-28-2017, 07:25 AM
LightningTeg's Avatar
I had a GT560R on my Stock LS and it was great. Maxxed out at 300whp/300trq and 21 lbs.
Old 10-28-2017, 07:41 AM
Chance EG's Avatar
I'm curious what impact an LS Vs. VTEC head would have on the top end for this turbo, with how small the exhaust profile is. Less head flow may almost be a good thing.
Old 10-30-2017, 01:25 AM
Balor_Gr's Avatar
It will be better if you tell us your goals and budget.
For example im not sure if youll find a cast iron t28 manifold for stock engine setup.
Old 10-30-2017, 04:21 AM
The turbo would just make the same power with less boost and would fall off more in the upper rpm range.
Old 10-30-2017, 11:06 AM
charosenz's Avatar
It is a V-TEC R18A. I had looked at that 2860 too....
thanks.
peacemaker
10-25-2007 02:22 PM
JSiRTO
10-09-2006 04:22 PM
petergriffen
03-11-2006 11:18 AM
B18PoweredCivic
05-03-2003 10:00 AM
supergodzilla
09-10-2001 01:18 PM
Quick Reply: anyone used a gt2560 turbo for daily driver?
