Suspension & Brakes Theory, alignment, spring rates....
Break issue
Old Oct 25, 2017 | 11:48 AM
anthony138's Avatar
Default Break issue
Hows it going guys. Just finished boosting my ls.i also replaced the brake booster check valve and all. But with the turbo the pedal gets super tight. No vaccum leaks i checked for those. Is it because of the turbo inducing soo much air? Should i put a vaccum pump in the car?
Old Oct 25, 2017 | 03:16 PM
spAdam's Avatar
Loved
Community Favorite
Default Re: Break issue
Is the check valve pointing in the correct direction?
Old Oct 27, 2017 | 04:18 PM
anthony138's Avatar
yes the check valve is in the right direction. Im getting so much vaccum its causing my calipers to lock shut.
Old Oct 27, 2017 | 04:58 PM
Tyson's Avatar
Your master cylinder and booster spacing is not adjusted properly.
Old Oct 27, 2017 | 08:17 PM
spAdam's Avatar
Loved
Community Favorite
Thats not how your booster works. Next check is what Tyson suggested.
Old Oct 30, 2017 | 08:06 PM
anthony138's Avatar
its just the front calipers sticking. i replaced booster, I've replaced the check valve, I've created space between master cylinder and the booster. i replaced the calipers and they're still sticking. prop valve? abs? i pulled all the fuses and the motor relay for the abs. i also drove with the ebrake up to try to get the abs to disengage and didn't get anywhere with it. I'm lost. my pedal isn't sinking to the floor. and my rears aren't sticking at all.
Old Oct 30, 2017 | 08:30 PM
Tyson's Avatar
You didn't adjust it properly.
Old Oct 31, 2017 | 04:48 AM
anthony138's Avatar
so the booster and master cylinder isn't adjusted properly? do you know the spacing ive looked everywhere and cant find it. and since my front calipers are sticking would the rod on the booster need to be shortened to shorten the throw of the pedal or do I need to elongate the throw of the rod?
Old Oct 31, 2017 | 08:35 AM
Tyson's Avatar
its in the manual.
Old Oct 31, 2017 | 08:46 AM
spAdam's Avatar
Loved
Community Favorite
Old Oct 31, 2017 | 08:50 AM
Tyson's Avatar
thats not it.
Old Oct 31, 2017 | 02:49 PM
spAdam's Avatar
Loved
Community Favorite
Is it because he has a master that’s mismatched to the booster? No info on chassis/master/booster was provided. Would he have to shim the master off of the booster in some case I’ve never run into?
Old Oct 31, 2017 | 06:07 PM
egsleepercivic's Avatar
I believe this is what Tyson is referring to
http://my.cardone.com/techdocs/PT%2053-0001.pdf
There used to be a honda-tech thread on how to do it, but haven't found it
Old Oct 31, 2017 | 07:01 PM
anthony138's Avatar
had nothing to do with the adjustment on the booster. its the abs. checked continuity on the system. she's getting power. i think the pump is completely shot I'm not getting the hum when she turns on. no abs light no codes for the pump being over run. i disconnected the abs module and was seeing if it would do anything tried to jump the system even bled it. still nada. i think the pump **** the bed and won't let fluid return and causing the front calipers to lock up.
Old Oct 31, 2017 | 08:05 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The manifold is not under vacuum when the turbo spools....
And decel will not pull any more vacuum than NA.
Old Oct 31, 2017 | 08:06 PM
B serious's Avatar
What do you mean it gets super tight?
Ar the brakes clamping without your foot being on the pedal?
Old Nov 1, 2017 | 05:01 AM
anthony138's Avatar
if I bleed the calipers to release the pistons, then I can spin the rotors. if I pump the brakes even a few times they lock up again. the abs module I think is bad. the relay and all is getting power. so I think either the module is bad or the pump for the abs is bad itself. its allowing fluid to pass through but not to release back out. it has new calipers new brackets new guide pins.
Old Nov 1, 2017 | 08:41 AM
spAdam's Avatar
Loved
Community Favorite
Has the unit ever been serviced? ABS modules need to be bled as well.
i totally forgot about that adjustment. I think I even have the tool floating around somewhere. That guide pretty much covers the process.
Old Nov 1, 2017 | 09:49 AM
Yeah I think the thread showed how to do it without the special tool, i don't remember 100% as it was years ago.
I am getting ready to swap to integra rotor\calipers in the front of my 93 si and a 15/16th MC from a 91 ex so this adjustment has been in the back of my mind
Old Nov 10, 2017 | 08:08 PM
did you get this sorted out?
Old Nov 14, 2017 | 02:02 PM
whydidibuythis's Avatar
Also curious to see if you got this solved yet.
Old Nov 16, 2017 | 06:37 PM
Doodasi's Avatar
Must have figured it out. If not, you need to open the brake line for the front on the master, and see if the wheels brake free. If not work your way down until you find the spot where it squirts fluid. The point before the line you open will be your blockage. Start at the beginning, not the end.
efsex
Aug 19, 2010 02:34 AM
3gcvcd16
Jun 25, 2008 09:55 AM
migs
May 11, 2005 07:26 AM
glass1
Nov 24, 2004 08:15 PM
jdm92accord
Jan 31, 2002 08:15 AM
