Passenger foot well huge leak above / behind ECU
Ive got a huge leak in my passenger footwell when it rains. I took the a-pillar cover off and ran water over the sunroof and can see it going down the tube and it appears fine. I dont have a glove box so it makes things a little easier to see but with the heater core in there its still not great. Its definatley not comming in through the blower motor. I re-did the cowl foam and tried to caulk it but with the amount of rain we have it all rinsed away.
Is there any easy way to remove the blower motor housing that the cabin filter goes into so I can see a little better?
Its a 1993 SI
Any one have any ideas? I heard there was an issue with seam sealer, but cant find much info on it.
Any help would be greatly appreciated as the GF is getting pretty pissed about this and it might mean ill have to get a new car if I cant get this sorted.
Its a 1993 SI
That would be the seam seal failure TSB.
Not the easiest to get to or do but is a known issue.
Please see the attached TSB.
TSB_A92-050.pdf
TSB_A92-050.pdf
dadof3
Nov 24, 2024 02:49 PM
civicdelsol33
Mar 18, 2013 12:38 AM
EH3Civic
Nov 16, 2007 06:36 AM
hbracer93
10
Jul 27, 2005 01:04 PM
