Coolant leaking into driver and passenger comparment
Hey what sup fellow HT members!
FYI. I am aware it might be a potential heater core leakage but before I dig through the whole dash, I just want to make sure of something. Already checked the hoses going into heater and show no signs of leakage.
I have 1993 civic hatchback si with b18c1. I have already located the coolant leak from one of the hoses connecting to the iacv and B-pipe.
My question is, is it possible for coolant to leak down into my compartments from the iacv and B-pipe. I did find a trail of coolant leaking down the undercarriage.
Fish Twig
Re: Coolant leaking into driver and passenger comparment
I was afraid someone was going to say this lol.
In that case, is it possible for these leaks to go into the compartments?
Do you have coolant stains on your firewall?
The only coolant lines I know that enter the cab is the heater core, of which all the rubber is on the outside, beyond that, there really isn't any other lines that would get coolant inside the car.
If the firewall was getting doused then maybe you could get a little seepage inside but your engine would have overheated long ago and you would have lots of coolant residue over the firewall.
You can easily look behind your center console at the bottom of the heater core/flapper box and tell if you have coolant coming out the bottom of the box. This will verify a bad core. The best view is from the passenger foot well.
