Coolant residue under new head gasket, burning oil, etc.
Old Oct 4, 2017 | 12:12 PM
Sprockets's Avatar
Default Coolant residue under new head gasket
Never mind, it was a leaking coolant hose.
Old Oct 4, 2017 | 01:17 PM
ls joker's Avatar
Loved
Default Re: Coolant residue under new head gasket, burning oil, etc.
Try rinsing it again, blowing it with compressed air to dry it, then put some baby powder down there to see if its new or residual. Has your idle changed or started to stall or bounce at all
Old Oct 4, 2017 | 02:04 PM
Dark_Teg's Avatar
Sounds like the oil control rings on the pistons are bad. Does the car smoke under a load? My last motor had perfect compression on all cylinders and even passed a leak down test. Did a re-ring and re-hone and all was good.
Old Oct 4, 2017 | 03:08 PM
Sprockets's Avatar
I didn't rinse that side, but I will. The idle is fine and the car runs OK.
No, I haven't noticed any smoke behind me under load lately. It wasn't full throttle tuned for quite some time, because I had to break in my Kevlar clutch. I wasn't able to boost or go over 4000 RPM during that time. When we did full throttle tune it, there was black smoke from carbon, not oil. How would oil get on the injectors if it's the rings, though?
So, if it does turn out to be the rings, I'd have to get new pistons as well and step up to 84.5mm?
Old Oct 5, 2017 | 05:13 AM
Dark_Teg's Avatar
IMO your are talking about too much oil to be valve guides or seals leaking. My intake was coated with oil on the inside as well. First thing I did was pull the head and have it rebuilt. The problem persisted so we did a re-ring and a re-hone and the problem went away.
Old Oct 5, 2017 | 06:37 AM
Chance EG's Avatar
If your cylinder walls are in good condition now as you previously indicated in your post, you should be able to re use your pistons and keep the same bore spec. A very light hone will be all that's needed to properly seat the new rings.
94hondajdm
Mar 15, 2013 05:56 PM
BiG_DeE
15
Aug 30, 2010 11:45 AM
djviet2000
23
Apr 29, 2008 09:36 PM
Shiftandgo
Sep 4, 2007 01:18 PM
zk91si
May 29, 2007 08:56 PM
