V tec lock pins??
Old Oct 1, 2017 | 08:29 PM
Jdmschulz99's Avatar
Default V tec lock pins??
im doing a mild turbo build and I still want to drive it on the street I got the speed factory pins and they are installed I was wondering if it is reliable to drive on weekends and if lmas are needed
Old Oct 2, 2017 | 02:29 AM
Chance EG's Avatar
Default Re: V tec lock pins??
Literally the first sentence on the SpeedFactory website about these pins:
These pin kits are designed to be used in drag race applications where the engine is operated at high RPM with limited idle/low rpm use, not in a street car.
I'm not sure why you're using this kit with a "mild" turbo build either. You're far from their intended use.
jdmchinoCDN
Nov 10, 2010 08:32 PM
Quickridez_3
Mar 8, 2008 02:58 AM
tegman23
Mar 26, 2007 10:14 AM
casmello
Apr 7, 2005 07:49 PM
Gsr94black
Nov 15, 2004 09:19 PM
