V tec lock pins??
V tec lock pins??
im doing a mild turbo build and I still want to drive it on the street I got the speed factory pins and they are installed I was wondering if it is reliable to drive on weekends and if lmas are needed
Re: V tec lock pins??
Literally the first sentence on the SpeedFactory website about these pins:
I'm not sure why you're using this kit with a "mild" turbo build either. You're far from their intended use.
These pin kits are designed to be used in drag race applications where the engine is operated at high RPM with limited idle/low rpm use, not in a street car.
Quickridez_3
03-08-2008 02:58 AM
