1991 Acura integra- **No crank**
when you go to start car you hear all the relays click, push the clutch pedal and you hear fuel pump and starter relay click but nothing at the starter. 12v at sig wire, 12v to starter all times during crank. ignition key wire white/black gets constant 12v. i noticed that with the key off the starter is still getting 12v like there is a back feed but can't find anything. i checked to make sure that the plastic is on the clutch pedal at the top and bottom for both interlock switches. what else can i be missing? thank you
new
battery, clean fresh grounds all around, 2x starters,
new
new
new
clikoyl
Nov 5, 2009 01:01 PM
