99 Teg constant vibration
Old 09-16-2017, 01:10 PM
Silver22's Avatar
Default 99 Teg constant vibration
Cranks right up. Goes to fast idle then backs down to normal. But there is vibration and what I call a growling noise, at idle and while driving. Whole car is vibrating and rear mirror even vibrates. It is an automatic.
Can this issue be narrowed down from the above information? Search indicates it could be: engine mount, harmonic balnacer, coil, accessory bearing, flex plate out of balance (on an auto?), water pump.
Just bought this great low mileage car and want to fix this issue. Thanks!
Old 09-16-2017, 01:47 PM
2x0
2x0's Avatar
Default Re: 99 Teg constant vibration
If it's at idle and while driving has to be coming from engine, either a misfire or engine mount.
Have someone watch the engine movement if you hold the brakes and give it a little gas while not moving but in gear (don't run them over). If it's a bad mount the engine will move a lot.
A bad misfire would normally throw a code but start by checking spark plugs, see if one looks lean or wet.
Old 09-16-2017, 02:54 PM
Silver22's Avatar
Thanks, 2x0. I'm pretty sure the engine isn't misfiring. I have not heard it skip a single time. But the engine mount sounds suspect. I hope that's all it is.
Old 09-17-2017, 04:52 PM
tamboo's Avatar
window weld those b**thches it works great if ur broke!
2 X DOW U-428+ Auto Glass Windshield Urethane Primerless Adhesive Glue Sealant | eBay
Old 09-17-2017, 06:33 PM
Silver22's Avatar
2 X DOW U-428+ Auto Glass Windshield Urethane Primerless Adhesive Glue Sealant eBay
Cool. That sounds like an awesome fix
Old 09-26-2017, 02:20 PM
Silver22's Avatar
Turned out it was the water pump bearing.
Old 10-01-2017, 06:01 PM
TNight's Avatar
Huh The water pump bearing was making the motor shake? Was there a noise ie squeak,grind,thump whirring ?
gogydm
12-11-2011 04:53 AM
RustyE.G.
08-12-2011 11:42 AM
bdmlilburn
05-05-2009 07:09 AM
satan_srv
08-09-2002 10:18 AM
Quick Reply: 99 Teg constant vibration
